I am using a device that is slow on returning values to snmp, this device has over 1k ports
I have disabled all pooling on ports that I don’t care about and it leaves me with 68 ports.
when I look it still times out, when I look at the logs I see Error in ports module. The process "'/usr/bin/snmpbulkwalk' '-v3' '-l' 'authPriv' '-n' "" '-a' 'SHA' '-A' 'AUTH' '-u' 'USER' '-x' 'AES' '-X' 'AES' '-OQUs' '-m' 'IF-MIB' '-M' '/opt/librenms/mibs' 'DEVICEDNSNAME:161' 'ifXEntry'" exceeded the timeout of 1200 seconds.
then /opt/librenms/poller.php 13 2021-05-03 15:10:05 - 1 devices polled in 1203. secs
I have set pooling to once every 25 min in cron and adjusted the config for Datastore:RRDTool to 1500
is there a place I can adjust the snmpbulkwalk timeout?
I changed it to not run bulkwalk and again I hit the timeout
I ran ./poller.php -d -h HOST -m ports
this is the same timeout as bulkwalk The process "'/usr/bin/snmpwalk' '-v3' '-l' 'authPriv' '-n' "" '-a' 'SHA' '-A' 'PASS' '-u' 'USER' '-x' 'AES' '-X' 'PASS' '-OQUs' '-m' 'IF-MIB' '-M' '/opt/librenms/mibs' 'HOST:161' 'ifXEntry'" exceeded the timeout of 1200 seconds.
I am working with the vendor to get this looked at SNMP on these devices is so SLOW.
but for now is there a hard coded timeout I can change?
I did try v2 and same thing, it is something up with the device that makes it take so long, this is a new SNMP implementation, and it is half baked, I don’t think they tested it on a device in the field.
thanks for pointing to the config variable, going to double it and see if that helps.
i have the same error on librenms.log
i think the timeout came from snmpbulkwalk downloading full internet route from the router/device, for about 800.000 route
is there any option to discard the poller for downloading the full route?
You cna disable the route module @buset1974 . Theoretically, if the SNMP implementation is not too old, the route module should receive the number of route, and if this number is more than a limit (1000 by default) skip all the routes.
If the implementation is too old, LibreNMS has now way to know the number of routes before discovering all of them, which means you have to manually disable the route discovery module.
