Please understand that it is not smooth because I am using a translator.
We use the same vendor’s equipment, but there is a problem that all graphs are displayed normally in A equipment, and certain parts are not displayed normally in other equipment B.
As a result of repeated inspections, it was confirmed that the model of the equipment and the OS were different.
Regardless of the model or version, if it is correct that the same vendor requested the same oid, we would like to set the exact oid value for each equipment by classifying the category by model/OS.
Below are the vendor equipment and what files can be fixed to resolve the issue?
thank you
