Currently my device sysName OID is based on the DEVICE-MIB file itself which OID Name is sysNodeName.
As per basic discovery, it only capture sysName with filename SNMPv2-MIB.
However, it capture null value. I tried manually using MIB Browser, which the sysName supposedly sysNodeName.
How do I point the sysName to sysNodeName?
Tried to change as per below:
modules:
os:
sysName: LUM-SYSTEM-MIB::sysNodeName.0
version: LUM-SYSTEM-MIB::sysNodeVersion.0
hardware: LUM-INVENTORY-MIB::invPhysModelName.138412032
serial: LUM-INVENTORY-MIB::invPhysSerialNum.138412032
However, it did not works.
Appreciate your kind help.
Best Regards
