LibreNMS currently doesn’t provide option to add a particular logical system (Juniper) using snmpv3 with context defination.
In the Juniper snmpv3 config, there is context definition and only the default system can be added using the default context. Logical systems can’t be add simple because there is no option to configure the context on the LibreNMS (Add Device)
when we use snmpwalk without the context:
snmpwalk -v3 -l authPriv -u tashicell -a SHA -A -x AES -X .1.3.6.1.2.1
Error in packet.
Reason: authorizationError (access denied to that object)
When we use snmpwalk with context:
snmpwalk -v3 -l authPriv -n cr1-thimphu/default -u tashicell -a SHA -A -x AES -X .1.3.6.1.2.1
iso.3.6.1.2.1.1.1.0 = STRING: “snmp for ar1.thimphu”
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.2636.1.1.1.2.29
an so on…
FYI: Juniper snmp config
v3 {
usm {
local-engine {
user tashicell {
authentication-sha {
authentication-key
privacy-aes128 {
privacy-key
vacm {
security-to-group {
security-model usm {
security-name tashicell {
group mysnmpv3;
access {
group mysnmpv3 {
default-context-prefix { - default chassis
security-level authentication {
read-view mysnmpv3view;
security-level privacy {
context-prefix ar1-thimphu/default { - logical system
context-prefix cr1-thimphu/default { - logical system
