[SOLVED] AD Authentication configured but its still using mysql
I’m running the latest LibreNMS (clean install yesterday) on CentOS 7.
Its been working fine with local users but been trying to add AD authentication. I think its added correctly but when I run auth_test.php it still says mysql:
[root@xxxxxx librenms]# ./scripts/auth_test.php -l
Authentication Method: mysql
Users: lewis (1)
Total users: 1
Here is my config.php
<?php
## Have a look in defaults.inc.php for examples of settings you can set here. DO NOT EDIT defaults.inc.php!
### Database config
$config['db_host'] = 'localhost';
$config['db_port'] = '3306';
$config['db_user'] = 'librenms';
$config['db_pass'] = 'xxxx';
$config['db_name'] = 'librenms';
$config['db_socket'] = '';
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config['user'] = 'librenms';
### Default community
$config['snmp']['community'] = "public";
$config['mydomain'] = 'xxxx.corp';
### Authentication Model
$config[‘auth_mechanism’] = "active_directory";
### List of RFC1918 networks to allow scanning-based discovery
#$config['nets'][] = "10.0.0.0/8";
#$config['nets'][] = "172.16.0.0/12";
#$config['nets'][] = "192.168.0.0/16";
# Update configuration
$config['update_channel'] = 'release';  # uncomment to follow the monthly release channel
#$config['update'] = 0;  # uncomment to completely disable updates
$config['discovery_by_ip'] = true;
#AD Authentication
$config[‘auth_ad_url’] = 'ldap://xx.xx.xx.xx'; // you can add multiple servers separated by a space
$config[‘auth_ad_domain’] = 'xxxx.corp';
$config[‘auth_ad_base_dn’] = 'DC=xxxx,DC=corp'; // groups and users must be under this dn#
$config[‘auth_ad_check_certificates’] = 0; // require a valid ssl certificate
$config[‘auth_ad_binduser’] = ‘xxxx’;
$config[‘auth_ad_bindpassword’] = 'xxxx';
$config[‘auth_ad_timeout’] = 5; // time to wait before giving up (or trying the next server)
$config[‘auth_ad_debug’] = true; // enable for verbose debug messages#
$config[‘active_directory’][‘users_purge’] = 25; // purge users who haven’t logged in for 25 days.
$config[‘auth_ad_require_groupmembership’] = true; // require users to be members of a group listed below
$config[‘auth_ad_groups’]['LibreNMS_Admins'][‘level’] = 10;
And here is the result of validate.php
[root@xxxxxx librenms]# ./validate.php
LibreNMS  | 1.47-52-gd33d879
DB Schema | 1000
PHP       | 7.2.13
MySQL     | 5.5.60-MariaDB
RRDTool   | 1.4.8
SNMP      | NET-SNMP 5.7.2
[OK]    Composer Version: 1.8.0
[FAIL]  The poller (xxxxx.xxxx.corp) has not completed within the last 5 minutes, check the cron job.
[WARN]  Some devices have not been polled in the last 5 minutes. You may have performance issues.
    Devices:
     10.50.0.250
     10.131.0.250
[WARN]  Your local git contains modified files, this could prevent automatic updates.
    Modified Files:
     bootstrap/cache/.gitignore
     logs/.gitignore
     rrd/.gitignore
     storage/app/.gitignore
     storage/app/public/.gitignore
     storage/debugbar/.gitignore
     storage/logs/.gitignore
What is causing it to still use mysql logins?
This is not related to the issue but you need to run the fix that is supplied to you in the validate.
You have used the wrong quote characters in your config, use '
Off topic.
I ran the cleanup and now get all this:
        SQL Statements:
         ALTER TABLE `access_points` CHANGE `accesspoint_id` `accesspoint_id` int(11) NOT NULL auto_increment;
         ALTER TABLE `access_points` CHANGE `device_id` `device_id` int(11) NOT NULL ;
         ALTER TABLE `alerts` CHANGE `id` `id` int(11) NOT NULL auto_increment;
         ALTER TABLE `alerts` CHANGE `device_id` `device_id` int(11) NOT NULL ;
         ALTER TABLE `alerts` CHANGE `rule_id` `rule_id` int(11) NOT NULL ;
         ALTER TABLE `alert_device_map` CHANGE `id` `id` int(11) NOT NULL auto_increment;
         ALTER TABLE `alert_device_map` CHANGE `rule_id` `rule_id` int(11) NOT NULL ;
         ALTER TABLE `alert_device_map` CHANGE `device_id` `device_id` int(11) NOT NULL ;
         ALTER TABLE `alert_group_map` CHANGE `id` `id` int(11) NOT NULL auto_increment;
         ALTER TABLE `alert_group_map` CHANGE `rule_id` `rule_id` int(11) NOT NULL ;
         ALTER TABLE `alert_group_map` CHANGE `group_id` `group_id` int(11) NOT NULL ;
         ALTER TABLE `alert_log` CHANGE `id` `id` int(11) NOT NULL auto_increment;
         ALTER TABLE `alert_log` CHANGE `rule_id` `rule_id` int(11) NOT NULL ;
         ALTER TABLE `alert_log` CHANGE `device_id` `device_id` int(11) NOT NULL ;
         ALTER TABLE `alert_rules` CHANGE `id` `id` int(11) NOT NULL auto_increment;
          and 209 more...
Changing the quotes resolved it! Rookie error.
Your schema is extremely incorrect (due to a bug upstream).
Check logs/daily.log for ? -> 1000 ... done to figure out the previous version.
Run SQL:
UPDATE dbSchema SET version=? LIMIT 1;
DROP TABLE migrations;
Run daily:
./daily.sh
Warning future visitors. Dropping the migrations table may not be the correct move. Maybe only DELETE FROM migrations where batch=1;
