After this weekend oxidized service doesn’t start, I suspect that the ./daily might have bricked it.
sudo systemctl status oxidized.service
● oxidized.service - Oxidized - Network Device Configuration Backup Tool
Loaded: loaded (/lib/systemd/system/oxidized.service; enabled; vendor preset: enabled)
Active: inactive (dead) since mån 2019-02-18 08:01:40 CET; 17min ago
Process: 2806 ExecStart=/usr/local/bin/oxidized (code=exited, status=0/SUCCESS)
Main PID: 2806 (code=exited, status=0/SUCCESS)
feb 18 08:01:40 NAME systemd[1]: Started Oxidized - Network Device Configuration Backup Tool.
feb 18 08:01:40 NAME oxidized[2806]: I, [2019-02-18T08:01:40.863048 #2806] INFO -- : Oxidized starting, running as pid 2806
feb 18 08:01:40 NAME oxidized[2806]: I, [2019-02-18T08:01:40.893439 #2806] INFO -- : lib/oxidized/nodes.rb: Loading nodes
feb 18 08:01:40 NAME oxidized[2806]: F, [2019-02-18T08:01:40.957343 #2806] FATAL -- : Oxidized crashed, crashfile written in /home/oxidized/.config/oxidized/crash
feb 18 08:01:40 NAME oxidized[2806]: 765: unexpected token at '<!doctype html>
feb 18 08:01:40 NAME oxidized[2806]: <html lang="en">
feb 18 08:01:40 NAME oxidized[2806]: <head>
feb 18 08:01:40 NAME oxidized[2806]: <title>Error</title>
feb 18 08:01:40 NAME oxidized[2806]: <meta charset="utf-8">
feb 18 08:01:40 NAME oxidized[2806]: <meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">
Looking at the crash dump I’m getting a error page with the below error.
I´ve verified the X-auth token and it´s okay, anyone has any ideas?
