[Solved] Validate (and daily.sh) Failing
I have noticed updates failing lately, so I tried to run validate.php, but that fails also! The output (similar failure for daily.sh),
./validate.php
In Request.php line 361:
  Invalid URI.
LibreNMS  | 24.10.1-43-g7f99ab9ea (2024-11-16T02:03:42-06:00)
DB Schema | Not Connected (0)
PHP       | 8.1.2-1ubuntu2.19
Python    | 3.10.12
Database  | Not Connected
SNMP      | 5.9.1
[OK]    Composer Version: 2.8.2
A known issue?
Thanks!
No known issue. Are you behind a proxy?
Also for the DB connection check your info in .env file
Thanks! I did check .env, this seemed odd,
APP_URL=http:///
I removed it, ran validate.php … OK, now, though it regenerated that same row :wink: . But daily.sh still fails, as below (and note, I did try to manually login to the DB, with the info in .env - it works!).
  Invalid URI.
Updating SQL-Schema                                FAIL
  Invalid URI.
Cleaning up DB                                     OK
  Invalid URI.
Thanks again.
Try setting it to the full URL of your instal
Found it - thanks for the pointers! It was due to the old (v8.1) version of PHP in Ubuntu.
Appreciate it!
Hi.
I ran command ./daily.sh and /opt/librenms/cronic /opt/librenms/poller-wrapper.py 16, the poller seemed to be working fine. However, after more than ten seconds, it became abnormal again. I also tried restarting the machine and the service, but it didn’t solve the problem.
Check your cron /etc/cron.d/librenms, sounds like that’s not configured or configured incorrectly.
Changed the parameters and the issue has been resolved, thanks !
