Some AD users work, some have no permissions - using same AD group
Another ‘My Active Directory isn’t behaving how it should’ query, similar to others I’ve found but not quite the same and/or they were from some time ago so probably not relevant.
Running librenms in docker, using latest tag, currently v 23.1.1.
Output from validate:
librenms:/opt/librenms$ ./validate.php
LibreNMS  | 23.1.1 (2023-02-09T19:33:37+00:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP       | 8.1.15
Python    | 3.10.10
Database  | MariaDB 10.11.2-MariaDB-1:10.11.2+maria~ubu2204
SNMP      | 5.9.3
[OK]    Installed from package; no Composer required
[OK]
[OK]    MySQl and PHP time match
[OK]    No python wrapper pollers found
[WARN]  Using database for locking, you should set CACHE_DRIVER=redis
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[OK]    rrd_dir is writable
[WARN]  Non-git install, updates are manual or from package
Myself and my team each have two AD accounts, one for day to day use and one for administrative work. Both of these accounts are in the ‘IT staff’ AD group, which is what I’m using as a librenms filter. Initially I also allowed read access to ‘Staff’ group but I’ve removed that while debugging.
In all cases, our ‘admin’ accounts can sign in to Librenms and have admin rights. Our ‘everyday’ accounts can sign in but have no access. Looking in the database, it sets level=0 for those accounts (level=10 for the admin accounts). I tried editing the database to set level to 10 for my normal account, and it showed as admin in the user list but reset to 0 as soon as I logged in.
auth_test.php runs fine with no errors or warnings and returns level=10 for both accounts, listing ‘IT staff’ in the group list.
librenms:/opt/librenms/scripts# ./auth_test.php -u k******5
Authentication Method: active_directory
AD bind success
Password:
Authenticate user k******5:
AUTH SUCCESS
User (1311):
  user_id => 1311
  username => k******5
  realname => Steve ******
  email => steve.*****@*****.****
  descr =>
  level => 10
  can_modify_passwd => 0
Groups: CN=IT staff,OU=Staff User Groups,OU=Groups,DC=**********
librenms:/opt/librenms/scripts# ./auth_test.php -u steve
AD bind success
Password:
Authenticate user steve:
AUTH SUCCESS
User (7874):
  user_id => 7874
  username => steve
  realname => Steve ****** (Admin)
  email => steve.*******@***.***
  descr =>
  level => 10
The configuration file for the AD setup:
<?php
$config['auth_mechanism'] = 'active_directory';
$config['auth_ad_url'] = 'ldaps://ad1.******** ldaps://ad2.********';
$config['auth_ad_domain'] = '**********';
$config['auth_ad_base_dn'] = 'dc=**************';
$config['auth_ad_check_certificates'] = false;
$config['auth_ad_binduser'] = 'librenmsbind';
$config['auth_ad_bindpassword'] = '***************';
$config['auth_ad_timeout'] = 5;
$config['auth_ad_debug'] = false;
$config['active_directory']['users_purge'] = 30;
$config['auth_ad_require_groupmembership'] = true;
$config['auth_ad_groups']['IT staff']['level'] = 10;
It’s clearly talking to AD, it’s getting the info. The group membership should be the same - clearly auth_test.php is thinking that it is. Running it with verbose/debug output didn’t give anything obvious, and no obvious errors being generated from the container.
The only things that have come to mind are:
Both accounts have the same email address. Although that’s not the case with my other team members, although their email address in AD was blank for the admin account.
The ‘everyday’ accounts are members of ‘IT staff’, while the admin accounts are members of an ‘Admin users’ account which is in turn a member of ‘IT staff’. I could understand it if these accounts didn’t work and the normal ones did, but that isn’t the case.
Does anyone have any ideas?
