This morning I am having some issues with some graphs drawing. Some work, while some do not. The error I get when looking at the rrd output is:
ERROR: rrdcached: rrd_fetch_r failed: mmaping file '/opt/librenms/rrd/switch01/port-id6787.rrd': Invalid argument
Either that file doesn’t exist, or it doesn’t have permission.
Run ./validate.php
I checked and the file does exist, but it looks empty. I ran the validate and got the following:
LibreNMS | 1.33-234-g712201e
DB Schema | 223
PHP | 7.0.22-0ubuntu0.16.04.1
MySQL | 10.0.31-MariaDB-0ubuntu0.16.04.2
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
Can you show the file permissions of the rrd file?
Also, are you using rrdcached?
I had to turn off RRDcached because something with the permissions was causing no graphs to be drawn even if I give the folders 777 access.
The permissions of all the files are “-rw-rw-r–”
Is rrdcached still enabled in your config.php?
If you follow the rrdcached docs, you won’t have any permissions issues. Make sure rrdcached is running with the correct command line switches.
https://docs.librenms.org/Extensions/RRDCached/
