SonicWall TZ and SNMPv3
I am switching a SonicWall TZ370 to use SNMPv3. I have it working but since changing, I no longer see ports or traffic. I did troubleshooting and verified I have access to OID’s and counters via snmpwalk with my creds and setup. I have tried this on more than one device. Everything else shows up for data and there was trafic and port data when using v2. I tried removing and re-adding device with no change. Graphs show Error drawing graph No Port on pop-up graph. Nothing displays on main device info for traffic, but does show everything else.
LibreNMS 25.11.0-dev.41+050e59dbc (2025-10-22T04:36:11-07:00)
DB Schema 2025_10_17_112553_bgp_peers_cbgp_bigint (358)
PHP 8.3.1
Python 3.9.2
Database MariaDB 10.5.29-MariaDB-0+deb11u1
SNMP 5.9
[OK] Composer Version: 2.8.12
Are you using SonicOS 7.3.0? It’s a duff release of SonicOS that doesn’t include 64-bit counters, regardless of SNMP protocol version. You have to ask support for a hotfix and no, it’s not in the release notes.
You will be glad to hear that SonicOS 7.3.1 claims to fix this and was just released.
