So, I have been looking around trying to find out why this device has not been pulling information. My understanding is that this issues was already addressed, but I don’t see why I am having problems if this problem was fixed.
Features
Added syslog alert transport (#6246 )
Send collected data to graphite server (#6201 )
Added SMART application support (#6181 )
Peeringdb integration to show the Exchanges and peers for your AS’ (#6178 )
Added support for sending alerts to Telegram #2114 (#6202 )
Added pbin.sh to upload text to p.libren.ms (#6175 )
Added better BGP support for Arista (#6046 )
Added rrd step conversion script (#6081 )
Store the username in eventlog for any entries created through the Webui (#6032 )
Added Nvidia G…
librenms:master
← laf:issue-6241
opened 10:23PM - 22 Mar 17 UTC
DO NOT DELETE THIS TEXT
#### Please note
> Please read this information ca… refully. You can run `./scripts/pre-commit.php` to check your code before submitting.
- [x] Have you signed the [Contributors agreement](http://docs.librenms.org/General/Contributing/) - please do NOT submit a pull request unless you have (signing the agreement in the same pull request is fine). Your commit message for signing the agreement must appear as per the docs.
- [x] Have you followed our [code guidelines?](http://docs.librenms.org/Developing/Code-Guidelines/)
#### Testers
Fixes: #6241
Updated Sonus SBC os detection #6241 (#6243 4)
How have any of you addressed this when you have encountered this issue? I ran across the steps to add a new OS, but since that was already done this does not seem to fit in that category.
Anyone familiar with the process on how I can get LibreNMS to recognize my OS and monitor my SBC Sonus devices?
You have not provided any information. LibreNMS already supports Sonus SBC OS.
Please supply this information: https://docs.librenms.org/Support/FAQ/#what-information-do-you-need-to-add-a-new-os
I already have that information for you, here you go:
https://p.libren.ms/view/5db209b8
https://p.libren.ms/view/56c480d7
https://p.libren.ms/view/987836c1
I already know that Sonus is supported, hence my problem. If Sonus is supported then why am I seeing it as a Generic Device?
This is what I am seeing:
