We’ve encountered that Disk space graph is no more available for new FreeBSD nodes which we recently added on LibreNMS. We’ve also enabled unix-agent but disk space graph is not there any more while old nodes can be seen with space graph. Here you can see the screenshot :-
Thanks in advance !!
Shahzaib
try running a discovery debug on that device. (Replace the HOSTNAME with your device name.) See in the output if finds the disk.
./discovery.php -h HOSTNAME -d
Looks like its only discovering one disk. and you said it found it before?
SQL[e[0;33mSELECT `storage_descr` FROM `storage` WHERE `device_id` = '30' AND `storage_type` != 'dsk'e[0m]
SQL[e[0;33mSELECT * FROM `storage` WHERE `device_id` = '30'e[0m]
try running ./discovery.php -h HOSTNAME -m storage -d
Yes, it is finding storage for existing FreeBSD nodes but not for newly added anymore . Here is the output of command :
https://pastebin.com/PPaYsfQa
I would check the snmpd config for that device make sure you no restrictions.
check this too -> https://docs.librenms.org/#Support/FAQ/#why-are-some-of-my-disks-not-showing
Problem is not if some storage device not showing up, problem is Disk storage Tab is nowhere.
I’ve updated snmp from _14 to _17 and looks like storage is shown up now
5.7.3_14 -> 5.7.3_17
