Sql errors - Please Help
can anyone help me out on the below error
librenms@librenms:~$ ./daily.sh
Fetching new release information OK
Updating to latest release OK
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
LibreNMS 21.4.0
DB Schema 2020_12_14_091314_create_port_group_port_table (202)
PHP 7.4.5
Python 3.6.9
MySQL 10.5.9-MariaDB-1:10.5.9+maria~bionic
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 2.0.13
./lnms migrate
librenms@librenms:~$ ./lnms migrate
  • Application In Production!     *
y
Migrating: 2020_12_14_091314_create_port_groups_table
In Connection.php line 678:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'port_groups
’ already exists (SQL: create table port_groups (id int unsigned not nu
ll auto_increment primary key, name varchar(255) not null, desc varchar
(255) null) default character set utf8mb4 collate ‘utf8mb4_unicode_ci’)
In Exception.php line 18:
’ already exists
In PDOStatement.php line 112:
’ already exists
We eventually solved that one here - see the solution linked under the question:
Error port device
Your DB version is not the issue, so dropping the tables and letting it re-run worked for others.
thank you
i have done that and can get back in the web gui
now i get the following issue
y
Migrating: 2021_04_08_151101_add_foreign_keys_to_port_group_port_table
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.port_gr
oup_port’ doesn’t exist (SQL: alter table port_group_port add constraint
port_group_port_port_group_id_foreign foreign key (port_group_id) refer
ences port_groups (id) on delete CASCADE)
Check post 29 from the same thread for the manual table creation perhaps, though it’s strange that the migrate seems to have continued on - some people hit that issue, but I didn’t:
What’s the output of the lnms migrate after it progressed past 2020_12_14_091314_create_port_group_port_table?
thank you
you have managed to help to resolve this issue :slight_smile:
