SQLSTATE[HY000] [1045] Access denied for user 'librenms'@'localhost' (using password: YES)
So i changed my Creds for the webserver
mysql & SSH as recommended, after I configured a nic for internet access. Updated ubuntu and Librenms
Upon validation
Blockquote
#1 /opt/librenms/syslog.php(20): process_syslog()
#2 {main}
[2021-05-30 21:03:58] production.ERROR: SQLSTATE[HY000] [1045] Access denied for user ‘librenms’@‘localhost’ (using password: YES) (SQL: INSERT IGNORE INTO syslog (device_id,program,facility,priority,level,tag,msg,timestamp) VALUES (1,LIBRENMS-SERVICE.PY,daemon,info,info,1e,librenms(WARNING):Too many DB failures (52), attempting to release master,2021-05-30 21:03:58)) (SQL: INSERT IGNORE INTO syslog (device_id,program,facility,priority,level,tag,msg,timestamp) VALUES (1,LIBRENMS-SERVICE.PY,daemon,info,info,1e,librenms(WARNING):Too many DB failures (52), attempting to release master,2021-05-30 21:03:58))#0 /opt/librenms/includes/syslog.php(166): dbInsert()
I checked a few threads advised to update the PHP and ENV file with my new creds
i assumed its these:
I was able to update the .php
but the .env file is empty, how do i proceed?
even if i stop and restart mysql and maria dd
im able to log onto mysql using my creds as well
You have to edit .env
Not config.env
Thanks man
