Ahsan
19 November 2024 14:53
1
Hi
Sometimes my Librenms stops responding and gives below error and i have to reboot server to fix it. there is enough space in disk as shown below.
.sudo -u librenms ./validate.php
LibreNMS | 24.10.1-50-g5f59ae051 (2024-11-17T20:22:32+05:00)
DB Schema | Not Connected (0)
PHP | 8.3.12
Python | 3.10.12
Database | Not Connected
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.8.2
[FAIL] Error connecting to your database.
[FAIL] Locking server issue: SQLSTATE[HY000] [2002] Connection refused (Connection: mysql, SQL: update `cache_locks` set `owner` = o2AGTjGxeGRVkQu8, `expiration` = 1732027797 where `key` = laravel_cache_dist_test_validation and (`owner` = o2AGTjGxeGRVkQu8 or `expiration` <= 1732027792))
In Connection.php line 829:
SQLSTATE[HY000] [2002] Connection refused (Connection: mysql, SQL: select * from `cache` where `key` = laravel_cache_scheduler_working limit 1)
In Connector.php line 65:
df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 392M 1.6M 390M 1% /run
/dev/sda2 118G 26G 87G 23% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
efivarfs 256K 58K 194K 23% /sys/firmware/efi/efivars
/dev/sda1 511M 6.1M 505M 2% /boot/efi
tmpfs 392M 80K 392M 1% /run/user/128
tmpfs 392M 72K 392M 1% /run/user/1000
Ahsan
19 November 2024 15:02
2
though i resolved the issue by restarting the service using below command
systemctl start mariadb.service
but why it happened ? any thing that i need to ensure to avoid its occurrence ?
laf
19 November 2024 16:00
3
This isn’t a LibreNMS issue really and rather a standard Linux sysadmin thing. Check all available logs and next time check that the service is actually already running.
Hi @laf , I am facing the same issue, checking the status of mysql indicates its starting and stopping every few seconds, Could this be a bug with the latest commit as this is when the issue started happening.
root@librenms:/opt/librenms# git log
commit 354aa370d1e9a1601ea0dd05f6c4edf629a999aa (HEAD -> master, origin/master, origin/HEAD)
Author: Kevin Zink <[email protected] >
Date: Wed Nov 20 01:05:02 2024 +0100
Hirschmann: Convert state sensors from inc.php to yaml (#16704)
* Hirschmann: Convert sensors from inc.php to yaml
* fix typo
* Fix index to not break historical data
* Update hirschmann.json
* Update hirschmann_ms4128.json
Co-authored-by: Neil Lathwood <[email protected] >
Error log
root@librenms:~# tail -F /opt/librenms/logs/librenms.log
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1016): array_walk()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(263): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(447): Illuminate\Foundation\Application->bootstrapWith()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(199): Illuminate\Foundation\Console\Kernel->bootstrap()
#33 /opt/librenms/app/Console/Kernel.php(66): Illuminate\Foundation\Console\Kernel->handle()
#34 /opt/librenms/artisan(35): App\Console\Kernel->handle()
#35 {main}
SQLSTATE[HY000] [2002] Connection refused (Connection: mysql, SQL: delete from `cache` where `key` = laravel_cache_illuminate:schedule:interrupt) {"exception":"[object] (Illuminate\\Database\\QueryException(code: 2002): SQLSTATE[HY000] [2002] Connection refused (Connection: mysql, SQL: delete from `cache` where `key` = laravel_cache_illuminate:schedule:interrupt) at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:829)
[previous exception] [object] (PDOException(code: 2002): SQLSTATE[HY000] [2002] Connection refused at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php:65)"}
tack trace:
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(983): Illuminate\Database\Connection->runQueryCallback()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(962): Illuminate\Database\Connection->tryAgainIfCausedByLostConnection()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(785): Illuminate\Database\Connection->handleQueryException()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(414): Illuminate\Database\Connection->run()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2913): Illuminate\Database\Connection->select()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2902): Illuminate\Database\Query\Builder->runSelect()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3456): Illuminate\Database\Query\Builder->Illuminate\Database\Query\{closure}()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2901): Illuminate\Database\Query\Builder->onceWithColumns()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(739): Illuminate\Database\Query\Builder->get()
#9 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(723): Illuminate\Database\Eloquent\Builder->getModels()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Concerns/BuildsQueries.php(333): Illuminate\Database\Eloquent\Builder->get()
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(568): Illuminate\Database\Eloquent\Builder->first()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(600): Illuminate\Database\Eloquent\Builder->firstOrCreate()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Traits/ForwardsCalls.php(23): Illuminate\Database\Eloquent\Builder->updateOrCreate()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2335): Illuminate\Database\Eloquent\Model->forwardCallTo()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(2347): Illuminate\Database\Eloquent\Model->__call()
#16 /opt/librenms/LibreNMS/Config.php(260): Illuminate\Database\Eloquent\Model::__callStatic()
#17 /opt/librenms/LibreNMS/Config.php(460): LibreNMS\Config::persist()
#18 /opt/librenms/LibreNMS/Config.php(61): LibreNMS\Config::processConfig()
#19 /opt/librenms/app/Providers/ConfigServiceProvider.php(27): LibreNMS\Config::load()
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\ConfigServiceProvider->boot()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1036): Illuminate\Container\Container->call()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1017): Illuminate\Foundation\Application->bootProvider()
#27 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation\{closure}()
#35 {main}
MySQL/MariaDB restarting every few seconds
root@librenms:~# systemctl status mysql
● mariadb.service - MariaDB 10.4.31 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─migrated-from-my.cnf-settings.conf
Active: activating (auto-restart) (Result: signal) since Wed 2024-11-20 05:59:19 CAT; 4s ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 1580959 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 1580961 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1580963 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_ST>
Process: 1581052 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=killed, signal=ABRT)
Process: 1581087 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1581089 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 1581052 (code=killed, signal=ABRT)
Status: "Taking your SQL requests now..."
Nov 20 05:59:19 librenms.liquidtelecom.zm systemd[1]: mariadb.service: Failed with result 'signal'.
Active: active (running) since Wed 2024-11-20 05:59:25 CAT; 1s ago
Docs: man:mysqld(8)
Process: 1581177 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 1581185 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1581188 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_ST>
Process: 1581313 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1581315 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 1581278 (mysqld)
Tasks: 32 (limit: 77026)
Memory: 113.8M
CGroup: /system.slice/mariadb.service
├─1581278 /usr/sbin/mysqld
└─1581331 addr2line -C -f -e /lib/x86_64-linux-gnu/libpthread.so.0
Active: activating (auto-restart) (Result: signal) since Wed 2024-11-20 05:59:30 CAT; 717ms ago
Docs: man:mysqld(8)
Process: 1581278 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=killed, signal=ABRT)
Main PID: 1581278 (code=killed, signal=ABRT)
root@librenms:~#
laf
20 November 2024 12:37
5
No, that wouldn’t trigger mysql to restart, LibreNMS in general is unlikely to do that. You need to check the mysql/mariadb log files.
Ahsan
21 November 2024 17:35
6
this is happneing frequently. i have to face this problem on daily basis. and have to manually restart mariadb. any idea what could be the root cause for this.
MariaDB is crashing, unfortunately, we don’t know how to help you with MariaDB, only LibreNMS.
You’ll need to check the MariaDB logs and search the errors or ask in the MariaDB community for help.
Ahsan
25 November 2024 14:27
8
نومبر 19 20:12:42 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-19 20:12:42 638 [Warning] Access denied for user ‘soaknms’@‘localhost’ (using password: NO)
نومبر 19 20:13:09 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-19 20:13:09 645 [Warning] Access denied for user ‘soaknms’@‘localhost’ (using password: NO)
نومبر 19 20:13:11 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-19 20:13:11 660 [Warning] Access denied for user ‘soaknms’@‘localhost’ (using password: NO)
نومبر 19 20:16:10 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-19 20:16:10 799 [Warning] Access denied for user ‘librenms’@‘localhost’ (using password: YES)
نومبر 19 22:07:36 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-19 22:07:36 6667 [Warning] Access denied for user ‘librenms’@‘localhost’ (using password: YES)
نومبر 20 00:00:04 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-20 0:00:04 3 [Warning] Aborted connection 3 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 21 00:00:02 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 0:00:02 12679 [Warning] Aborted connection 12679 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 21 20:25:31 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 20:25:31 187056 [Warning] Aborted connection 187056 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 21 20:37:21 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 20:37:14 187694 [Warning] Aborted connection 187694 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 21 20:37:55 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 20:37:55 187771 [Warning] Aborted connection 187771 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error writing communication packets)
نومبر 21 20:37:55 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 20:37:55 187706 [Warning] Aborted connection 187706 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error writing communication packets)
نومبر 21 20:38:28 MyNMS-virtual-machine mariadbd[1719708]: 2024-11-21 20:38:28 187813 [Warning] Aborted connection 187813 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 21 20:40:24 MyNMS-virtual-machine systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
نومبر 21 20:40:24 MyNMS-virtual-machine systemd[1]: mariadb.service: Main process exited, code=killed, status=9/KILL
نومبر 21 20:40:24 MyNMS-virtual-machine systemd[1]: mariadb.service: Failed with result ‘oom-kill’.
نومبر 21 20:40:26 MyNMS-virtual-machine systemd[1]: mariadb.service: Consumed 10h 31min 19.499s CPU time.
نومبر 21 22:29:27 MyNMS-virtual-machine systemd[1]: Starting MariaDB 10.6.18 database server…
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] Starting MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 source revision 887bb3f73555ff8a50138a580ca8308b9b5c069c as process 2994107
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Number of pools: 1
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Using liburing
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Completed initialization of buffer pool
نومبر 21 22:29:28 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:28 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=30077602970,30078546280
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: To recover: 299 pages
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: 128 rollback segments are active.
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: Creating shared tablespace for temporary tables
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: 10.6.18 started; log sequence number 30078644587; transaction id 89770688
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] Plugin ‘FEEDBACK’ is disabled.
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
نومبر 21 22:29:29 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:29 0 [Note] Server socket created on IP: ‘127.0.0.1’.
نومبر 21 22:29:30 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:30 0 [Note] /usr/sbin/mariadbd: ready for connections.
نومبر 21 22:29:30 MyNMS-virtual-machine mariadbd[2994107]: Version: ‘10.6.18-MariaDB-0ubuntu0.22.04.1’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 Ubuntu 22.04
نومبر 21 22:29:30 MyNMS-virtual-machine systemd[1]: Started MariaDB 10.6.18 database server.
نومبر 21 22:29:30 MyNMS-virtual-machine /etc/mysql/debian-start[2994125]: Upgrading MySQL tables if necessary.
نومبر 21 22:29:30 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-21 22:29:30 0 [Note] InnoDB: Buffer pool(s) load completed at 241121 22:29:30
نومبر 21 22:29:30 MyNMS-virtual-machine /etc/mysql/debian-start[2994137]: Checking for insecure root accounts.
نومبر 21 22:29:30 MyNMS-virtual-machine /etc/mysql/debian-start[2994141]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
نومبر 22 00:00:04 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-22 0:00:04 3 [Warning] Aborted connection 3 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 23 00:00:05 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-23 0:00:05 5823 [Warning] Aborted connection 5823 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 24 00:00:14 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-24 0:00:14 97077 [Warning] Aborted connection 97077 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 25 00:00:13 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-25 0:00:13 146594 [Warning] Aborted connection 146594 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 25 00:26:30 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-25 0:26:30 191585 [Warning] InnoDB: Could not free any blocks in the buffer pool! 8109 blocks are in use and 0 free. Consider increasing innodb_buffer_pool_size.
نومبر 25 00:32:39 MyNMS-virtual-machine mariadbd[2994107]: 2024-11-25 0:32:39 191370 [Warning] Aborted connection 191370 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 25 00:35:23 MyNMS-virtual-machine systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
نومبر 25 00:35:24 MyNMS-virtual-machine systemd[1]: mariadb.service: Main process exited, code=killed, status=9/KILL
نومبر 25 00:35:24 MyNMS-virtual-machine systemd[1]: mariadb.service: Failed with result ‘oom-kill’.
نومبر 25 00:35:24 MyNMS-virtual-machine systemd[1]: mariadb.service: Consumed 1d 1h 35min 26.248s CPU time.
– Boot 2dccc5ab419c48ab9632bbabbecb13f9 –
نومبر 25 12:00:43 MyNMS-virtual-machine systemd[1]: Starting MariaDB 10.6.18 database server…
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] Starting MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 source revision 887bb3f73555ff8a50138a580ca8308b9b5c069c as process 995
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Number of pools: 1
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Using liburing
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
نومبر 25 12:00:45 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:45 0 [Note] InnoDB: Completed initialization of buffer pool
نومبر 25 12:00:46 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:46 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=34819420076,34820306769
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: To recover: 519 pages
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: 128 rollback segments are active.
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: Creating shared tablespace for temporary tables
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: 10.6.18 started; log sequence number 34822206618; transaction id 102997239
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] Plugin ‘FEEDBACK’ is disabled.
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
نومبر 25 12:00:50 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:50 0 [Note] Server socket created on IP: ‘127.0.0.1’.
نومبر 25 12:00:51 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:51 0 [Note] /usr/sbin/mariadbd: ready for connections.
نومبر 25 12:00:51 MyNMS-virtual-machine mariadbd[995]: Version: ‘10.6.18-MariaDB-0ubuntu0.22.04.1’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 Ubuntu 22.04
نومبر 25 12:00:52 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:00:52 0 [Note] InnoDB: Buffer pool(s) load completed at 241125 12:00:52
نومبر 25 12:00:52 MyNMS-virtual-machine systemd[1]: Started MariaDB 10.6.18 database server.
نومبر 25 12:00:52 MyNMS-virtual-machine /etc/mysql/debian-start[1306]: Upgrading MySQL tables if necessary.
نومبر 25 12:00:52 MyNMS-virtual-machine /etc/mysql/debian-start[1317]: Checking for insecure root accounts.
نومبر 25 12:00:52 MyNMS-virtual-machine /etc/mysql/debian-start[1321]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
نومبر 25 12:24:11 MyNMS-virtual-machine mariadbd[995]: 2024-11-25 12:24:11 250 [Warning] Aborted connection 250 to db: ‘librenms’ user: ‘librenms’ host: ‘localhost’ (Got an error reading communication packets)
نومبر 25 12:25:35 MyNMS-virtual-machine systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
نومبر 25 12:25:36 MyNMS-virtual-machine systemd[1]: mariadb.service: Main process exited, code=killed, status=9/KILL
نومبر 25 12:25:36 MyNMS-virtual-machine systemd[1]: mariadb.service: Failed with result ‘oom-kill’.
نومبر 25 12:25:38 MyNMS-virtual-machine systemd[1]: mariadb.service: Consumed 5min 49.561s CPU time.
نومبر 25 15:12:43 MyNMS-virtual-machine systemd[1]: Starting MariaDB 10.6.18 database server…
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] Starting MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 source revision 887bb3f73555ff8a50138a580ca8308b9b5c069c as process 58814
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Number of pools: 1
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Using liburing
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Completed initialization of buffer pool
نومبر 25 15:12:44 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:44 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=34840101783,34841386612
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: 1 transaction(s) which must be rolled back or cleaned up in total 1 row operations to undo
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Trx id counter is 103054779
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: To recover: 488 pages
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: 128 rollback segments are active.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Starting in background the rollback of recovered transactions
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Creating shared tablespace for temporary tables
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Rolled back recovered transaction 103054772
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Rollback of non-prepared transactions completed
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: 10.6.18 started; log sequence number 34843605376; transaction id 103054781
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] Plugin ‘FEEDBACK’ is disabled.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] Server socket created on IP: ‘127.0.0.1’.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:46 0 [Note] /usr/sbin/mariadbd: ready for connections.
نومبر 25 15:12:46 MyNMS-virtual-machine mariadbd[58814]: Version: ‘10.6.18-MariaDB-0ubuntu0.22.04.1’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 Ubuntu 22.04
نومبر 25 15:12:46 MyNMS-virtual-machine systemd[1]: Started MariaDB 10.6.18 database server.
نومبر 25 15:12:47 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 15:12:47 0 [Note] InnoDB: Buffer pool(s) load completed at 241125 15:12:47
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58834]: Looking for ‘mariadb’ as: /usr/bin/mariadb
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58834]: Looking for ‘mariadb-check’ as: /usr/bin/mariadb-check
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58834]: This installation of MariaDB is already upgraded to 10.6.18-MariaDB.
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58834]: There is no need to run mysql_upgrade again for 10.6.18-MariaDB.
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58834]: You can use --force if you still want to run mysql_upgrade
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58842]: Checking for insecure root accounts.
نومبر 25 15:12:47 MyNMS-virtual-machine /etc/mysql/debian-start[58846]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
نومبر 25 16:11:05 MyNMS-virtual-machine mariadbd[58814]: 2024-11-25 16:11:05 3346 [Warning] InnoDB: Could not free any blocks in the buffer pool! 8112 blocks are in use and 0 free. Consider increasing innodb_buffer_pool_size.
نومبر 25 16:15:08 MyNMS-virtual-machine systemd[1]: mariadb.service: A process of this unit has been killed by the OOM killer.
نومبر 25 16:15:08 MyNMS-virtual-machine systemd[1]: mariadb.service: Main process exited, code=killed, status=9/KILL
نومبر 25 16:15:08 MyNMS-virtual-machine systemd[1]: mariadb.service: Failed with result ‘oom-kill’.
نومبر 25 16:15:12 MyNMS-virtual-machine systemd[1]: mariadb.service: Consumed 25min 17.989s CPU time.
نومبر 25 18:29:36 MyNMS-virtual-machine systemd[1]: Starting MariaDB 10.6.18 database server…
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] Starting MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 source revision 887bb3f73555ff8a50138a580ca8308b9b5c069c as process 192388
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Number of pools: 1
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Using liburing
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Completed initialization of buffer pool
نومبر 25 18:29:36 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:36 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=34902112693,34906811970
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: 1 transaction(s) which must be rolled back or cleaned up in total 1 row operations to undo
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Trx id counter is 103237873
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: To recover: 667 pages
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: 128 rollback segments are active.
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Starting in background the rollback of recovered transactions
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Creating shared tablespace for temporary tables
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Rolled back recovered transaction 103237871
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Rollback of non-prepared transactions completed
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: 10.6.18 started; log sequence number 34907925647; transaction id 103237875
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] Plugin ‘FEEDBACK’ is disabled.
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
نومبر 25 18:29:37 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:37 0 [Note] Server socket created on IP: ‘127.0.0.1’.
نومبر 25 18:29:38 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:38 0 [Note] /usr/sbin/mariadbd: ready for connections.
نومبر 25 18:29:38 MyNMS-virtual-machine mariadbd[192388]: Version: ‘10.6.18-MariaDB-0ubuntu0.22.04.1’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 Ubuntu 22.04
نومبر 25 18:29:38 MyNMS-virtual-machine systemd[1]: Started MariaDB 10.6.18 database server.
نومبر 25 18:29:38 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:29:38 0 [Note] InnoDB: Buffer pool(s) load completed at 241125 18:29:38
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192408]: Looking for ‘mariadb’ as: /usr/bin/mariadb
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192408]: Looking for ‘mariadb-check’ as: /usr/bin/mariadb-check
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192408]: This installation of MariaDB is already upgraded to 10.6.18-MariaDB.
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192408]: There is no need to run mysql_upgrade again for 10.6.18-MariaDB.
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192408]: You can use --force if you still want to run mysql_upgrade
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192416]: Checking for insecure root accounts.
نومبر 25 18:29:38 MyNMS-virtual-machine /etc/mysql/debian-start[192420]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
نومبر 25 18:35:31 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:35:31 232 [Warning] Access denied for user ‘librenms’@‘localhost’ (using password: YES)
نومبر 25 18:35:48 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:35:48 233 [Warning] Access denied for user ‘librenms’@‘localhost’ (using password: YES)
نومبر 25 18:35:55 MyNMS-virtual-machine mariadbd[192388]: 2024-11-25 18:35:55 234 [Warning] Access denied for user ‘librenms’@‘localhost’ (using password: YES)
laf
25 November 2024 15:49
9
Ahsan:
oom-kill
That’s probably your issue, have a google for it and I’m sure you’ll find lots on what to do to resolve it.
jaysen
26 November 2024 04:26
10
I have encountered both of these issues in past installs and I see two issues going on.
First, access is being denied by MariaDB to the user librenms@localhost. To fix this, just add another user called librenms@localhost and make sure you grant all privileges to the librenms database to this new user then flush privileges. The MySQL commands to create the user and privileges are in the setup guide. Make sure you use the same password that you used when you did your installation. This should solve your access denied issue.
Second, the oom-killer is due to your server running out of memory. If you are running your entire installation on a small VPS. You may need to upgrade it to the next server tier to include more RAM. You can use the top and free commands to inspect your processes and memory usage. If it shows you are using swap memory then I highly recommend you consider upgrading. I’d start with the simplest thing by fixing the access denied issue first.
There are of course many other MySQL tweaks you can do to tune the server but I’ve always found that to be a huge pain. Start with the simple stuff and see what happens. As always, make a backup before making any changes.
system
Closed
24 February 2025 04:27
11
