I want to ask what are the parameters should I use to monitor SSH
I’m using Nagios plugin
Best Regards
Best Regards
Check the CLI help and test it as the librenms user - then you’ll have all you need to put in the options:
librenms@host:/usr/lib/nagios/plugins$ ./check_ssh --help
All it actually needs is the hostname in normal usage though, so literally no settings and it works on mine.
Now it works
