i tried to install SSL Certificate in Apache server in Ubuntu 16.04 server …i have a correct syntax under
but as i enable ssl module ( sudo a2enmod ssl) ;the site do not browse and if i revert back disabling ssl module it works as it is working.
Do i need any other configuration to change??? I followed tutorials of librenms and some other tutorials but it didn’t worked for me.
Ok i agree with that it’s not the issue of Libre but what about apache?? How to solve this issue??? syntax is ok, since it is wildcard certificate i have been using in another subdomain too so i am damn sure it’s not the issue of certificate… How to solve this problem? please help me in this issue
Have i said this is a apache support? We are able to install libre in apache servers so i am asking for support here. I am here because may be we can deal with it editing ‘config. php’, file otherwise i do also have sense. If you have any idea on installing and troubleshooting in apache then do support me otherwise let the other people help me.
yeah i have searched everywhere and i think i have followed right instruction there is no warning or errors in configuration but its not work… lets hope
I have given full rights to the folder where ssl certificates are kept and while checking apache configuration it says the sytanx is ok… what i missed previously was i forgot to enable ssl module;i have enable that too now… and the main thing is regarding ports, sincle ssl listen in 443 ports by default, it was not in listening state now i have made it to listen… furthermore there are no any errors now but also it’s not working… so there is no any idea what to troubleshoot now… so much confused
