would you please let me know what does it mean this error? and how can I fix it?
please consider oxidized and librenms are in same server.
config file:
rest: X.X.X.X:443
source:
default: http
debug: false
http:
url: https://x.x.x.x:443/api/v0/oxidized
scheme: https
map:
after running oxidized:
INFO – : Oxidized starting, running as pid 1454606
INFO – : lib/oxidized/nodes.rb: Loading nodes
FATAL – : Oxidized crashed, crashfile written in /home/oxidized/.config/oxidized/crash
SSL_connect returned=1 errno=0 state=error: tlsv1 alert internal error
Crash file:
SSL_connect returned=1 errno=0 state=error: tlsv1 alert internal error [OpenSSL::SSL::SSLError]
/usr/lib/ruby/2.7.0/net/protocol.rb:44:in connect_nonblock' /usr/lib/ruby/2.7.0/net/protocol.rb:44:in ssl_socket_connect’
/usr/lib/ruby/2.7.0/net/http.rb:1009:in connect' /usr/lib/ruby/2.7.0/net/http.rb:943:in do_start’
/usr/lib/ruby/2.7.0/net/http.rb:932:in start' /usr/lib/ruby/2.7.0/net/http.rb:1483:in request’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/source/http.rb:74:in read_http' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/source/http.rb:21:in load’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:15:in block in load' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:130:in synchronize’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:130:in with_lock' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:10:in load’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/nodes.rb:125:in initialize' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:14:in new’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:14:in initialize' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:4:in new’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/core.rb:4:in new' /var/lib/gems/2.7.0/gems/oxidized-0.26.3/lib/oxidized/cli.rb:13:in run’
/var/lib/gems/2.7.0/gems/oxidized-0.26.3/bin/oxidized:8:in <top (required)>' /usr/local/bin/oxidized:23:in load’
/usr/local/bin/oxidized:23:in `’
Welcome to the Oxidized help section.
You are free to ask any questions surrounding Oxidized, it does not need to be specific to LibreNMS integration.
