SSL Nginx - can anyone post working config for Debian - SOLVED
I’m having a hard time getting SSL working, for several reasons.
For one I cannot use certbot or any online SSL. So I`m going to get the certificates from another source (Big offline 90% windows network - so the administrator will create somekind of certificate)
So If anyone have a working nginx config they can post that would be fantastic so I have something that works 100%. The official guide really confuses me.
This is my librenms.vhost
server {
 listen      80;
 listen      [::]:443 ssl;
 include snippets/self-signed.conf;
 include snippets/ssl-params.conf;
 server_name sub.domain.com;
 root        /opt/librenms/html;
 index       index.php;
 charset utf-8;
 gzip on;
 gzip_types text/css application/javascript text/javascript application/x-javascript image/svg+xml text/plain text/xsd t> location / {
 location ~ [^/]\.php(/|$) {
  fastcgi_pass unix:/run/php-fpm-librenms.sock;
  fastcgi_split_path_info ^(.+\.php)(/.+)$;
  include fastcgi.conf;
 location ~ /\.(?!well-known).* {
  deny all;
and this is my conf.d/librenms
server {
    listen         80;
    listen         [::]:80;
    return         301 https://$server_name$request_uri;
server {
 listen              443 ssl http2;
 listen              [::]:443 ssl http2;
 index       index.php;
 access_log  /opt/librenms/logs/access_log;
 error_log   /opt/librenms/logs/error_log;
But I cannot even connect to the server
And netstat -tulpn shows me that nginx tcp6 has a open port on 443 but not tcp4
This is my librenms.vhost file
server {
 server_name librenms.example.com;
 index       index.php;
 ssl_certificate /etc/ssl/STAR_netviscom_com.pem;
 ssl_certificate_key /etc/ssl/STAR_netviscom_com.key;
 charset utf-8;
 gzip on;
 location / {
  fastcgi_param  PHP_VALUE "memory_limit=4098M";
  deny all;
server {
 listen      80;
 return 301  https://librenms.example.com$request_uri;
 location /nginx-status {
  stub_status on;
  access_log   off;
  allow 127.0.0.1;
  deny all;
Thanks for the reply @Wolfraider - what does your /etc/nginx/conf.d/domain.conf look like?
Edit: my issue it that the index.php downloads! So there is perhaps a small php-config error at one config!
So this my new configs:
My /etc/nginx/conf.d/librenms.conf
server {
  listen 80;
  listen [::]:80;
  return 301 https://$host$request_uri;
server {
  listen 443 ssl;
  index       index.php;
  ssl_certificate /etc/nginx/certs/sub.domain.com.crt;
  ssl_certificate_key /etc/nginx/certs/sub.domain.com.key;
  ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
  ssl_prefer_server_ciphers on;
And my /etc/nginx/sites-enabled/librenms.vhost (from @Wolfraider )
server {
 index       index.php;
 charset utf-8;
 gzip on;
 gzip_types text/css application/javascript text/javascript application/x-javascript image/svg+xml text/plain text/xsd text/xs> location / {
  deny all;
server {
 listen      80;
 return 301  https://sub.domain.com$request_uri;
  stub_status on;
  access_log   off;
  allow 127.0.0.1;
  deny all;
But still the index.php downloads! should the .vhost file and .conf-file be similar like this?
Edit: /etc/nginx/sites-available/ is empty - just for the record
I don’t have one. I have my librenms.vhost under site-enabled and that’s it. I used the direcctions under Installing LibreNMS - LibreNMS Docs and added SSL and 443 redirect.
That is what I conclued as well, there is none. I removed the file in /etc/nginx/conf.d/librenms.conf and all the sudden everything works.
