I have set up SSO with Microsoft and I can log in and that works fine. My problem is that I set my self as an admin and I cannot see any of my devices setting etc. Here is a snip of the config.php. Also where in the world is th “db config” hiding at?
Authentication Model
#$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
$config[‘auth_mechanism’] = “sso”;
$config[‘sso’][‘mode’] = “env”;
#$config[‘sso’][‘group_strategy’] = “static”;
#$config[‘sso’][‘static_level’] = “10”;
$config[‘sso’][‘create_users’] = true;
$config[‘sso’][‘update_users’] = true;
$config[‘sso’][‘email_attr’] = “mail”;
$config[‘sso’][‘realname_attr’] = “displayName”;
$config[‘sso’][‘descr_attr’] = “unscoped-affiliation”;
$config[‘sso’][‘group_strategy’] = “map”;
$config[‘sso’][‘group_attr’] = “member”;
$config[‘sso’][‘group_level_map’] = [‘librenms-admins’ => 10, ‘librenms-readers’ => 1, ‘librenms-billingcontacts’ => 5];
$config[‘sso’][‘group_delimiter’] = ‘;’;
