In the ‘All Ports’ table (and anywhere else the field is displayed), the ‘Status Changed’ column says ‘a few seconds’ for every port of every device. Previously this information was displaying accurately. Issue seems to correspond with upgrading packages on my system as I noticed the issue after doing so.
Below is my server release and I’ve also attached truncated poller output from a cmd I found in another thread.
Any help is greatly appreciated.
$ >> uname -a
Linux deathstar 4.8.0-39-generic #42-Ubuntu SMP Mon Feb 20 11:47:27 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
$ >> lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.10
Release: 16.10
Codename: yakkety
http://pastebin.com/u52avEAs
I have this to, is there a way to solve this ?
I’ve got the same problem with ports of all devices.
example
I still have this bug, I have run the .daily.sh as librenms.
| Component |
Version |
| LibreNMS |
097a8277590b862b715ce86a9600da21eb35ba8f |
| DB Schema |
167 |
| PHP |
7.0.15-0ubuntu0.16.04.4 |
| MySQL |
5.7.17-0ubuntu0.16.04.1 |
| RRDTool |
1.5.5 |
| SNMP |
NET-SNMP 5.7.3 |
What else could be missing ?
I can confirm that updating to the newest version solves the problem.
Seems someone may have fixed the bug? It’s working for me again.
Think it is fixed with the new update. Have installed it yesterday and status changed to the right value. So you can change the state to solved I guess.
