Helllo,
After fix #17104 on storage_perc_warn at 25.2.0 if you change the value to a device, it returns to 60 after autodiscovery.
The problem still exists in 25.3.0
| Component |
Version |
| LibreNMS |
25.3.0 (2025-03-17T01:10:07+02:00) |
| DB Schema |
2025_03_11_031114_drop_ospfv3ifinstid (321) |
| PHP |
8.3.14 |
| Python |
3.8.10 |
| Database |
MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2 |
| RRDTool |
1.7.2 |
| SNMP |
5.8 |
[OK] Composer Version: 2.8.6
librenms@librenms:~$
Can you show your discoveyydebug output?
After further investigation problem exists only on huawei switches..
Here is the storage section of the discoverydebug
Load disco module storage
SNMP[‘/usr/bin/snmpbulkwalk’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/huawei’ ‘-m’ ‘SNMPv2-TC:SNMPv2-MIB:IF-MIB:IP-MIB:TCP-MIB:UDP-MIB:NET-SNMP-VACM-MIB’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUt’ ‘-Pu’ ‘-Ob’ ‘-t’ ‘2’ ‘udp:HOSTNAME:161’ ‘HUAWEI-FLASH-MAN-MIB::hwStorageTable’]
HUAWEI-FLASH-MAN-MIB::hwStorageType.1 = flash
HUAWEI-FLASH-MAN-MIB::hwStorageSpace.1 = 259764
HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree.1 = 60104
HUAWEI-FLASH-MAN-MIB::hwStorageName.1 = flash:
HUAWEI-FLASH-MAN-MIB::hwStorageDescr.1 =
Using flash from $pre_cache[1][HUAWEI-FLASH-MAN-MIB::hwStorageType] for HUAWEI-FLASH-MAN-MIB::hwStorageType
Using flash: from $pre_cache[1][HUAWEI-FLASH-MAN-MIB::hwStorageName] for HUAWEI-FLASH-MAN-MIB::hwStorageName
Using 259764 from $pre_cache[1][HUAWEI-FLASH-MAN-MIB::hwStorageSpace] for HUAWEI-FLASH-MAN-MIB::hwStorageSpace
Using 60104 from $pre_cache[1][HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree] for HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree
SQL[select * from storage where storage.device_id = ? and storage.device_id is not null [272] 1.37ms]
SQL[update storage set storage_perc_warn = ? where storage_id = ? [60,892] 0.66ms]
Updated data:
array (
‘storage_perc_warn’ => 60,
flash: (flash): 77% 194.98 MiB / 253.68 MiB
Runtime for discovery module ‘storage’: 0.0430 seconds with 115544 bytes
SNMP: [1/0.04s] MySQL: [2/0.02s] RRD: [0/0.00s]
Unload disco module storage
Nope.. still autodiscovery reverts the value to 60.
It’s the first time that i run script github-apply. do i need to run something more to commit the change? script ran successfully.
| Component |
Version |
| LibreNMS |
| DB Schema |
| PHP |
8.3.14 |
| Python |
3.8.10 |
| Database |
| RRDTool |
1.7.2 |
| SNMP |
5.8 |
Modified Files:
LibreNMS/Modules/Storage.php
app/Providers/AppServiceProvider.php
HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree.1 = 59064
Using 59064 from $pre_cache[1][HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree] for HUAWEI-FLASH-MAN-MIB::hwStorageSpaceFree
SQL[select * from storage where storage.device_id = ? and storage.device_id is not null [272] 0.67ms]
SQL[update storage set storage_perc_warn = ? where storage_id = ? [60,892] 0.49ms]
Updated data:
array (
flash: (flash): 77% 196 MiB / 253.68 MiB
Runtime for discovery module ‘storage’: 0.0470 seconds with 118464 bytes
SNMP: [1/0.04s] MySQL: [2/0.01s] RRD: [0/0.00s]
We are still seeing the issue after discovery as well. Keeps resetting TrueNas warn percentages.
@murrant, in our case with TrueNas devices, I’ve noticed it doesn’t reset all of the warning percentages. It only resets the percentage after the first dozen or so storage entries.
@chaigeo, are you seeing discovery reset all the storage values or just some?
I’m seeing it reset on TrueNas devices at storage entry 26 on one device and entry 23 on another.
Yes still resets the values but only on huawei switches (i have multiple with diffenet firmware some with latest). I have only one value for a simple switch (flash:) and two values for stac switches. (flash: and slot1#flash:). in fact it is the same storage but librenms writes two values because of different snmp oid. problem exists in both types. problem exists to all and all values.
Same happens to our NetApp devices: The storage_perc_warn is reset to the default value (lnms config:get storage_perc_warn) during each discovery.
Still seeing this issue as well.
The only way it could be “reset” is if the drive is removed and re-added (on recent versions). Definitely could be the case if you have a device with flaky snmp/network.
