Strange issue
I could not figure out if cron job is running properly .
when I run ./validate.php from user librenms which I already added into sudoer list .
Getting this msg.
librenms@NMS:~$ ./validate.php
LibreNMS 1.36-44-g9777963
DB Schema 234
PHP 7.0.22-0ubuntu0.16.04.1
MySQL 10.0.31-MariaDB-0ubuntu0.16.04.2
RRDTool 1.5.5
SNMP NET-SNMP 5.7.3
[WARN] Your install is over 24 hours out of date, last update: Thu, 08 Feb 2018 05:28:46 +0000
then I ran daily.sh manually
librenms@NMS:~$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
nothing happen :confused:
Regards
in config.php:
Must be commented for update.
Update configuration
#$config[‘update_channel’] = ‘release’; # uncomment to follow the monthly release channel
#$config[‘update’] = 0; # uncomment to completely disable updates
