String value in Custom OID is not available. It’s possible this new feature?
I need to get SSID from AP.
Hi @Facundo_Bertran
Right now we are graphing the received value … So we cannot graph an SSID in a COUNTER type RRD, the error makes sense.
If you want an SSID, you probably need to play with Wireless discovery code, that is exactly meant for this use.
Ok. Thansk!
