Support for port security logs for hp switch
If it’s an issue with the WebUI then please consider including the browser version you are using.
On zenoss, I can see log records like ‘port XX security violation’.
I can not see a message like ‘port XX security violation’ on librenms in logs from separate hardware.
I want to see these log messages on librenms. Can you help me with this?
Hardware: HP ProCurve J9088A Switch 2610-48
Did you setup syslog? https://docs.librenms.org/#Extensions/Syslog/
