Support for Ubiquiti Solarpoint
Hi
Could I request that Ubiquiti’s solarpoint is added. It’s picking it up as a generic linux device at the moment so isn’t including voltages etc.
SNMP dump. https://p.libren.ms/view/a1881104
https://dl.ui.com/solar/mib/20191129/UBNT-SUNMAX-MIB
Did you get this added? We need to add a few and it wont pull the correct data.
Don’t believe it did. Custom OID’s you want are
Battery Temp .1.3.6.1.4.1.41112.1.11.1.1.4.0
Battery Voltage .1.3.6.1.4.1.41112.1.11.1.1.2.0
Output Power .1.3.6.1.4.1.41112.1.11.1.3.3.0
Panel Power .1.3.6.1.4.1.41112.1.11.1.2.3.0
Panel Voltage .1.3.6.1.4.1.41112.1.11.1.2.2.0
