I am trying to get which port (Interface name and Description) is down in my switch by alert notifications. I only get a “Port status up/down” notification. I have no clue how to use ports.ifAlias in alert rules. Please help me. Thank you.
Please, post your alert rule and alert template.
@sakibmahmud
you’ve got the Doc helping you…he’s awesome. I’ll just throw a little of what i know into the mix.
port.ifAlias you can do one of two things:
- you can set on the switch / router itself. I run HP and the syntax is interface 0/1 name “my_server”
- librenms is amazing and allows you to alter this description without modifying the switch/router config. Click on a device–>cog on right for device–>port settings. Right hand column you will see “description” field where you can edit.
So for example you could have “Servers: Server01, Servers: Server01” or “Core: Link-to-switch-1 | Core: Link-to-switch-2” Then you can set an alert like this
some action when port.ifAlias = “Server:” or port.ifAlias = “Core:” meets some condition, like down or whatever.
Sir, Currently I do not have any alert rule and alert template.
Thank you for your advice!
Take the Port status up/down
from rule collection or, as you said you dont have none, click the green button that sais “Create the default ones”.
You should have a Ports
template that comes by default.
Edit the template then attach the Port status up/down rule to that template
If you also want ifDescr in the template, just add (or edit) a new line with:
Port Descr: {{ $value['ifDescr'] }}
Thank you so much for your help.
I did everything you said, but only get “Alert for device switch003.local - Port status up/down” on transport.
Component | Version |
LibreNMS | 1.66-41-g73b7636c9 |
DB Schema | 2020_07_29_143221_add_device_perf_index (172) |
PHP | 7.2.24-0ubuntu0.18.04.6 |
Python | 3.6.9 |
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.10
What transport are you using? What you get is the tittle, but is missing the body.
SMS web API. I’m adding {{ $msg }} to transport. Thank you.
Remember SMSs have a text limitation, so you can end sending 4 or 5 SMSs for each notification.
I suggest you to edit the template so you get just the needed info.
I’ll keep this in my mind. Thank you so much.
I applied the exact template
but i m Port Status I get blank space
can u suggest?
