Switching from Apache to nginx
Today I switched from apache2 to nginx on my raspberry pi librenms setup.
And everything went on just fine, then I checked if smokeping was working from http://host.com/smokeping - and got 404. So I went down the rabbit hole of installing smokeping by following this official guide and that went on just fine as well until I met this little gem:
Add the following configuration to your /etc/nginx/conf.d/librenms.conf file within server section.
And I went to open librenms.conf in /etc/nginx/conf.d - there was nothing there? I had a look the official install guides as well, nothing about /etc/nginx/conf.d/librenms.conf there either.
Can someone paste the output of their /etc/nginx/conf.d/librenms.conf?
I need to paste this in the server section:
# Browsing to `http://yourlibrenms/smokeping/` should bring up the smokeping web interface
location = /smokeping/ {
        fastcgi_intercept_errors on;
        fastcgi_param   SCRIPT_FILENAME         /usr/lib/cgi-bin/smokeping.cgi;
        fastcgi_param   QUERY_STRING            $query_string;
        fastcgi_param   REQUEST_METHOD          $request_method;
        fastcgi_param   CONTENT_TYPE            $content_type;
        fastcgi_param   CONTENT_LENGTH          $content_length;
        fastcgi_param   REQUEST_URI             $request_uri;
        fastcgi_param   DOCUMENT_URI            $document_uri;
        fastcgi_param   DOCUMENT_ROOT           $document_root;
        fastcgi_param   SERVER_PROTOCOL         $server_protocol;
        fastcgi_param   GATEWAY_INTERFACE       CGI/1.1;
        fastcgi_param   SERVER_SOFTWARE         nginx/$nginx_version;
        fastcgi_param   REMOTE_ADDR             $remote_addr;
        fastcgi_param   REMOTE_PORT             $remote_port;
        fastcgi_param   SERVER_ADDR             $server_addr;
        fastcgi_param   SERVER_PORT             $server_port;
        fastcgi_param   SERVER_NAME             $server_name;
        fastcgi_param   HTTPS                   $https if_not_empty;
        fastcgi_pass unix:/var/run/fcgiwrap.socket;
location ^~ /smokeping/ {
        alias /usr/share/smokeping/www/;
        index smokeping.cgi;
        gzip off;
I tried to paste this info in the librenms.vhost-file and did not fly.
The doco mentions it with the sample file: Installing LibreNMS - LibreNMS Docs
Use that example, then all the smokeping stuff goes within the server { } block, eg: before the final } in the file.
Thanks alot! my ctrl+F did not find this!
But Smokeping still 404s - but atleast got the correct file :slight_smile:
