Hi All,
I seem to have run into an interesting problem with the syslog feature in LibreNMS.
Today I’ve replaced a switch and the new switch is taking the same IP address as the original switch.
In the past I’ve just let LibreNMS rediscover the new switch on the same IP addres and update the model number/interfaces etc, however the issue with doing that is that you can end up with some confused historical statistics/graphs etc since port assignments are no longer the same etc…also old syslog entries that don’t make sense in the context of a completely different model of switch.
So this time I thought I would simply delete the old device from LibreNMS to blow away any remnants of data saved for the old switch and re-add the same IP address as a new device.
This worked fine except for one thing - syslog no longer seems to work for this device, eg Logs->Logging->Syslog just says “No results found!” despite the fact that the new switch is configured to send syslog messages.
I have rsyslog configured on ubuntu server with the recommended reporting plugin for LibreNMS and this has been working great and continues to work for other devices.
At first I thought it might be an issue with the new switch however I checked /var/log/syslog - which is also configured to log everything network devices send to the LibreNMS server via syslog and I can see syslog messages from that particular switch (along with other switches) so the messages are definitely being received by rsyslog, logged, and I see no reason why the LibreNMS plugin wouldn’t be passing them on to LibreNMS as well.
When I deleted the old device and added the new one with the same IP address it now has a different device ID in LibreNMS - the only thing I can think of is that there is still some hidden database link in LibreNMS that is causing syslog messages from that IP address to be funnelled through to a now non-existent device, hence it doesn’t show up in the logs section of the new device that has taken on that IP address.
As I don’t really know how the logging/database in LibreNMS works I’m at a loss how to troubleshoot this issue. Anyone have any ideas ?
