I am using syslog-ng (v3.5.6) on CentOS 7.9 with LibreNMS v21.9.0-10 to capture syslog feeds from clients. The feeds from external clients defined with source s_net work fine, but the localhost’s own logs which should be captured via source s_sys are empty when I go to inspect them in LibreNMS’ Syslog viewer.
I know source s_sys is working because syslog-ng is writing to /var/log/messages with this config added to the recommended one in /etc/syslog-ng/syslog-ng.conf:
I figured out a workaround for anyone interested in seeing the LibreNMS localhost’s syslog feed inside LibreNMS’ Syslog viewer in the GUI.
I enabled debugging with syslog-ng-ctl debug --set=on long enough to capture some traffic and see how it compared to the hosts I’m monitoring via TCP & UDP. I noticed the messages from localhost lacked the $HOST parameter:
Incoming log entry; line='<131>Oct 4 15:05:19 andyTestLocalLog: TESTLOG on Mon Oct 4 15:05:19 EDT 2021'
Contrast with an entry from another host shipping syslog:
Incoming log entry; line='<30>Oct 4 15:00:01 remoteHostname systemd: Started Session 2352 of user root.
This lead me to figure the destination template expecting a $HOST value might break however syslog.php is handling the raw syslog feed. Here is the recommended entry per the docs:
I’m simply hard-coding the localhost’s FQDN into the template definition so that a value is present for syslog.php to pass to the database. This also requires adjustments to the log definitions in /etc/syslog-ng/syslog-ng.conf:
