Sorry something in my last post went horribly wrong…
That was a no go, is it possible my syslog.php file is corrupted or wrong?
<?php
// FIXME : use db functions properly
// $device_id_host = @dbFetchCell("SELECT device_id FROM devices WHERE `hostname` = '".mres($entry['host'])."' OR `sysName` = '".mres($entry['host'])."'");
// $device_id_ip = @dbFetchCell("SELECT device_id FROM ipv4_addresses AS A, ports AS I WHERE A.ipv4_address = '" . $entry['host']."' AND I.port_id = A.port_id");
use LibreNMS\Config;
function get_cache($host, $value)
global $dev_cache;
if (!isset($dev_cache[$host][$value])) {
switch ($value) {
case 'device_id':
// Try by hostname
$ip = inet_pton($host);
if (inet_ntop($ip) === false) {
$dev_cache[$host]['device_id'] = dbFetchCell('SELECT `device_id` FROM devices WHERE `hostname` = ? OR `sysName` = ?', array($host, $host));
} else {
$dev_cache[$host]['device_id'] = dbFetchCell('SELECT `device_id` FROM devices WHERE `hostname` = ? OR `sysName` = ? OR `ip` = ?', array($host, $host, $ip));
// If failed, try by IP
if (!is_numeric($dev_cache[$host]['device_id'])) {
$dev_cache[$host]['device_id'] = dbFetchCell('SELECT `device_id` FROM `ipv4_addresses` AS A, `ports` AS I WHERE A.ipv4_address = ? AND I.port_id = A.port_id', array($host));
break;
case 'os':
$dev_cache[$host]['os'] = dbFetchCell('SELECT `os` FROM devices WHERE `device_id` = ?', array(get_cache($host, 'device_id')));
break;
case 'version':
$dev_cache[$host]['version'] = dbFetchCell('SELECT `version` FROM devices WHERE `device_id`= ?', array(get_cache($host, 'device_id')));
break;
case 'hostname':
$dev_cache[$host]['hostname'] = dbFetchCell('SELECT `hostname` FROM devices WHERE `device_id` = ?', array(get_cache($host, 'device_id')));
break;
default:
return null;
}//end switch
}//end if
return $dev_cache[$host][$value];
}//end get_cache()
function process_syslog($entry, $update)
global $config, $dev_cache;
foreach ($config['syslog_filter'] as $bi) {
if (strpos($entry['msg'], $bi) !== false) {
return $entry;
$entry['host'] = preg_replace("/^::ffff:/", "", $entry['host']);
if ($new_host = Config::get("syslog_xlate")[$entry['host']]) {
$entry['host'] = $new_host;
$entry['device_id'] = get_cache($entry['host'], 'device_id');
if ($entry['device_id']) {
$os = get_cache($entry['host'], 'os');
$hostname = get_cache($entry['host'], 'hostname');
if ((isset($config['enable_syslog_hooks'])) && ($config['enable_syslog_hooks']) && (isset($config['os'][$os]['syslog_hook'])) && (is_array($config['os'][$os]['syslog_hook']))) {
foreach ($config['os'][$os]['syslog_hook'] as $k => $v) {
$syslogprogmsg = $entry['program'].": ".$entry['msg'];
if ((isset($v['script'])) && (isset($v['regex'])) && ((preg_match($v['regex'], $syslogprogmsg)))) {
shell_exec(escapeshellcmd($v['script']).' '.escapeshellarg($hostname).' '.escapeshellarg($os).' '.escapeshellarg($syslogprogmsg).' >/dev/null 2>&1 &');
if (in_array($os, array('ios', 'iosxe', 'catos'))) {
// multipart message
if (strpos($entry['msg'], ':') !== false) {
$matches = array();
$timestamp_prefix = '([\*\.]?[A-Z][a-z]{2} \d\d? \d\d:\d\d:\d\d(.\d\d\d)?( [A-Z]{3})?: )?';
$program_match = '(?%?[A-Za-z\d\-_]+(:[A-Z]* %[A-Z\d\-_]+)?)';
$message_match = '(?.*)';
if (preg_match('/^' . $timestamp_prefix . $program_match . ': ?' . $message_match . '/', $entry['msg'], $matches)) {
$entry['program'] = $matches['program'];
$entry['msg'] = $matches['msg'];
unset($matches);
} else {
// if this looks like a program (no groups of 2 or more lowercase letters), move it to program
if (!preg_match('/[(a-z)]{2,}/', $entry['msg'])) {
$entry['program'] = $entry['msg'];
unset($entry['msg']);
} elseif ($os == 'linux' and get_cache($entry['host'], 'version') == 'Point') {
// Cisco WAP200 and similar
$matches = array();
if (preg_match('#Log: \[(?P.*)\] - (?P.*)#', $entry['msg'], $matches)) {
unset($matches);
} elseif ($os == 'linux') {
$matches = array();
// pam_krb5(sshd:auth): authentication failure; logname=root uid=0 euid=0 tty=ssh ruser= rhost=123.213.132.231
// pam_krb5[sshd:auth]: authentication failure; logname=root uid=0 euid=0 tty=ssh ruser= rhost=123.213.132.231
if (empty($entry['program']) and preg_match('#^(?P([^(:]+\([^)]+\)|[^\[:]+\[[^\]]+\])) ?: ?(?P.*)$#', $entry['msg'], $matches)) {
} // SYSLOG CONNECTION BROKEN; FD='6', SERVER='AF_INET(123.213.132.231:514)', time_reopen='60'
// pam_krb5: authentication failure; logname=root uid=0 euid=0 tty=ssh ruser= rhost=123.213.132.231
// Disabled because broke this:
// diskio.c: don't know how to handle 10 request
// elseif($pos = strpos($entry['msg'], ';') or $pos = strpos($entry['msg'], ':')) {
// $entry['program'] = substr($entry['msg'], 0, $pos);
// $entry['msg'] = substr($entry['msg'], $pos+1);
// fallback, better than nothing...
elseif (empty($entry['program']) and !empty($entry['facility'])) {
$entry['program'] = $entry['facility'];
unset($matches);
} elseif ($os == 'procurve') {
$matches = array();
if (preg_match('/^(?P[A-Za-z]+): {2}(?P.*)/', $entry['msg'], $matches)) {
$entry['msg'] = $matches['msg']. " [". $entry['program']. "]";
unset($matches);
} elseif ($os == 'zywall') {
// Zwwall sends messages without all the fields, so the offset is wrong
$msg = preg_replace("/\" /", '";', stripslashes($entry['program'].':'.$entry['msg']));
$msg = str_getcsv($msg, ';');
$entry['program'] = null;
foreach ($msg as $param) {
list($var, $val) = explode("=", $param);
if ($var == 'cat') {
$entry['program'] = str_replace('"', '', $val);
$entry['msg'] = join(" ", $msg);
}//end if
if (!isset($entry['program'])) {
$entry['program'] = strtoupper($entry['program']);
$entry = array_map('trim', $entry);
if ($update) {
dbInsert(
array(
'device_id' => $entry['device_id'],
'program' => $entry['program'],
'facility' => $entry['facility'],
'priority' => $entry['priority'],
'level' => $entry['level'],
'tag' => $entry['tag'],
'msg' => $entry['msg'],
'timestamp' => $entry['timestamp'],
'syslog'
unset($os);
}//end if
return $entry;
}//end process_syslog()
