Syslog troubleshooting
I have a particular device (a Sencore IRD) that is causing syslog issues. I am not sure how to go about tracing down what syslog-ng, or maybe librenms, doesn’t “like” about the messages this device is sending. I poked around in the librenms logs, looked in /var/log and there is nothing in there relating to these devices. My /var/log/syslog log filea haven’t been touched since January. I don’t have any way to modify the syntax of these messages in the Sencores, so I am stuck trying to sort this out in Librenms.
Pretty sure I need to create a special syslog conf file to deal with these. Plenty of other devices have no issues and display syslog messages just fine.
Was hoping to find a log file where I could “stare and compare” messages that worked vs these, but no luck. Not looking for anyone to fix this for me, just need a shove in the right direction.
text of syslog message
Error processing log message: <13>1 2019-10-25T04:00:05Z 192.168.100.94 MRD4400 - EvtLog [ManagedEventLog@9986 Uni>@<t Alias="D-----------------------3" evtlogLabel="scte35msgOccurred" evtlogInst=".1.1" evtlogSeverity="1"] Decoder: SCTE35: splice insert for Source 0x0, Event 0x0000008, Program 0, Avail 0 of 0
validate.php output
LibreNMS 1.53.1
DB Schema 2019_05_30_225937_device_groups_rewrite (135)
PHP 7.2.19-0ubuntu0.18.04.2
MySQL 10.1.41-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.9.0
Modified Files:
.codeclimate.yml
