Sysobjectid, sys name, hardware rev appear, then disappear
Hi
First time user, just getting setup with 10 devices to monitor
I have 3 DLINK switches im trying to monitor, and when first discovered, all the info about the device gets pulled:
|2018-02-24 21:45:05||sysObjectID -> .1.3.6.1.4.1.171.10.76.27|
|2018-02-24 21:45:05||sysName -> poe_switch|
|2018-02-24 21:45:05||sysDescr -> DGS-1210-24P 4.21.B008|
|2018-02-24 21:45:05||Location -> Loft|
and then 10 mins later, something happens, and all the data is missing
2018-02-24 21:55:11 sysObjectID ->
2018-02-24 21:55:11 sysName ->
2018-02-24 21:55:11 sysDescr ->
2018-02-24 21:55:11 Hardware -> Rev.
2018-02-24 21:51:02 Could not issue recovery for rule ‘Devices up/down’ to transport ‘mail’ Error: You must provide at least one recipient email address.
2018-02-24 21:51:02 Could not issue critical alert for rule ‘Port status up/down’ to transport ‘mail’ Error: You must provide at least one recipient email address.
Any idea why the device would discover properly, and then this would happen?
I am still getting all the stats from the device, and my graphs are populating with data, i can see interface graphs etc etc, its just this info that goes missing!
Please run and post ./validate.php
and pastebin the following
./discovery.php -h HOSTNAME -d
and
./poller.php - HOSTNAME -d
Hi, thanks for responding.
Validate:
LibreNMS 1.37
DB Schema 237
PHP 7.0.9
MySQL 5.5.47-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[FIX] Check your poll log and see
Devices:
192.168.1.1
192.168.1.9
Discover
Poller
that Dlink switch is not repsonding to
i think there was fix for this try updating your librenms install.
thanks - ive tried daily.sh and seems am up to date?
[[email protected] ~]$ ./daily.sh
Updating Composer packages OK
Updated from ff02fce to 1d45d4b OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[[email protected] ~]$ ./validate.php
LibreNMS 1.37-1-g1d45d4b
DB Schema 237
PHP 7.0.9
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
If its a known problem, thats cool, assume it will get sorted at some point?
Have you tried updating the dlink firmware?
I dont think its a “known” issue i think its buggy SNMP implention by Dlink.
