Techroute Switch add
DO NOT REMOVE THIS TEXT WITHOUT FIRST READING IT AND THEN PROVIDING THE INFORMATION ASKED FOR.
IF YOU DO NOT PROVIDE THE INFORMATION REQUIRED THEN YOUR MESSAGE WILL BE REMOVED
Please provide the output from the following commands (check for sensitive information in the links created before you post them here). If you need to redact any information then please copy the contents from the pastebin, edit and paste the contents to a “pastebin”, we recommend using https://paste.rs/ or https://paste.sh/
./discovery.php -h HOSTNAME -d = https://paste.sh/OvJygIvX#4fdlNAfzxrVCKU-cQXQihPNK
lnms device:poll HOSTNAME -vv | curl --data-binary @- https://paste.rs/
snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME .  | curl --data-binary @- https://paste.rs/
