Telegram Template Alert title Recovery title Problem
Version : 1.50-46-ga08b833 - Thu Apr 18 2019 10:15:31 GMT+0900
DB Schema : 2019_02_10_220000_add_dates_to_fdb (132)
Web Server : Apache/2.4.6 (CentOS) PHP/7.2.17
PHP : 7.2.17
MySQL : 5.5.60-MariaDB
RRDtool : 1.6.0
When sending a telegram alarm, “Alert title”, “Recovery title” will not be sent but only contents will be sent.
In the case of a mail alarm, it is normal.
There was no problem until it was updated.
Can you tell if it’s a Librenms issue or a telegram issue?
Mines works as spected.
Do you mind posting your template?
hi~
“replace title” is not sent.
You forgot to add it to the template!
Add this {{ $alert->title }} at the beggining of the template
Telegram doesnt have a Subjet field (like the emails one) so you need to add the title to the template itself.
It is good ~
Oh ~ Thank you very much ~
