I have configured my switch’s temperature health settings as below:
I have set up these alerts:
SELECT * FROM devices,sensors WHERE (devices.device_id = ? AND devices.device_id = sensors.device_id) AND sensors.sensor_current > “sensors.sensor_limit” AND sensors.sensor_class = “temperature” AND sensors.sensor_alert = 1
SELECT * FROM devices,sensors WHERE (devices.device_id = ? AND devices.device_id = sensors.device_id) AND sensors.sensor_current > “sensors.sensor_limit_warn” AND sensors.sensor_class = “temperature” AND sensors.sensor_alert = 1
For some reason both alerts are triggering even though the current temperature hasn’t exceeded either threshold. Any ideas why?
I also tried tweaking the alerts with a syslog.timestamp >= “macros.past_10m” condition but then I can’t get the alerts to trigger ever, no matter what I set the health settings to (regardless of delay/interval level).
I can’t see what I’m doing wrong ![]()
