I have problems with Temperature sensor rule. When I applied to only on device everything work well. But when I applied to whole devices, I receive fault temperature notifications. The alert template is the default one.
Image no. 3 is when I apply the rule to only one device (everything works well).
Image no. 4 is when I apply the rule to all devices (I got wrong temperature alert on Chasis 1)
Thank you!
