Hi. I have inserted librenms into a teracom TCW220 device. Librenms detects the device, but does not read any OID. I can’t read any temperature, voltage, relay, etc.
How can I read these values?
Hi Toni
Do you have found any solution to this problem?
Hi @M_Andersson @Toni_M
You need to add support or fill an issue for these devices :
http://docs.librenms.org/Support/FAQ/#faq20
Keep in mind that filling an issue does not mean that somebody will pick it and code it.
Bye
