Hello all !
Component
Version
LibreNMS
21.8.0-41-g0a76ca444
DB Schema
2021_25_01_0129_isis_adjacencies_nullable (217)
PHP
7.3.20
Python
3.6.8
MySQL
10.3.28-MariaDB
RRDTool
1.7.0
SNMP
NET-SNMP 5.8
For test I used
curl -i -X GET “https://api.telegram.org/botxxxxxxxx/sendMessage?chat_id=xxxxx&text=hello ”
from console, telegram got message but from LibreNMS Error.
did you check the logs for which error this gives? Have you chatted with the bot before and is the configuration correct? Can the NMS-server reach the API?
Is the chat id and token in the correct format? For example, for this URL
https://api.telegram.org/bot123456:ABC-DEF1234ghIkl-zyx57W2v1u123ew11/getMe
the correct token would be 123456:ABC-DEF1234ghIkl-zyx57W2v1u123ew11
Now telegram alerting working well, but when I press test button appears error !
Strangely.
system
Closed
24 December 2021 01:00
#4
