Hello I am attempting to run Test Units for a new OS before making a PR. Following Test Units - LibreNMS Docs step 9.
Running lnms dev:check unit --db --snmpsim times out with error lower in the thread.
- Set the .env file options for DEV and the test DB.
- Run
lnms dev:check unit --db --snmpsimorlnms dev:check unit --db - Wait…
- What I have tried.
- copying the db
librenmsto the test db
- copying the db
The output of ./validate.php
Note: This is a development box I expect to see some WARN and FAIL around git and the scheduler.
librenms@LibreNMS-DEV:~$ ./validate.php
LibreNMS | 24.9.0 (2024-10-11T12:34:51+00:00)
DB Schema | 2024_10_06_002633_ports_vlans_table_add_port_id_index (301)
PHP | 8.1.2-1ubuntu2.19
Python | 3.10.12
Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.8.1
[WARN] Debug enabled. This is a security risk.
[WARN] You have no devices. [FIX]:
Consider adding a device such as localhost: /addhost
[WARN] PHP version 8.2 is the minimum supported version as of October, 2024. We recommend you update PHP to a supported version (8.3 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[FAIL] Scheduler is not running
[FIX]: sudo cp /opt/librenms/dist/librenms-scheduler.service /opt/librenms/dist/librenms-scheduler.timer /etc/systemd/system/
sudo systemctl enable librenms-scheduler.timer
sudo systemctl start librenms-scheduler.timer
[WARN] Your install is over 24 hours out of date, last update: Fri, 11 Oct 2024 12:34:51 +0000 [FIX]:
[WARN] Your local git branch is not master, this will prevent automatic updates. [FIX]:
You can switch back to master with git checkout master
Error:
............................................................. 1464 / 3267 ( 44%)
............................................................. 1525 / 3267 ( 46%)
............................................................. 1586 / 3267 ( 48%)
............................................................. 1647 / 3267 ( 50%)
............................................................. 1708 / 3267 ( 52%)
............................................................. 1769 / 3267 ( 54%)
............................................................. 1830 / 3267 ( 56%)
............................................................. 1891 / 3267 ( 57%)
............................................................. 1952 / 3267 ( 59%)
............................................................. 2013 / 3267 ( 61%)
............................................................. 2074 / 3267 ( 63%)
............................................................. 2135 / 3267 ( 65%)
......^.........^............................................ 2196 / 3267 ( 67%)
............................................................. 2257 / 3267 ( 69%)
............................................................. 2318 / 3267 ( 70%)
............................................................. 2379 / 3267 ( 72%)
Symfony\Component\Process\Exception\ProcessTimedOutException
The process "'vendor/bin/phpunit' '--colors=always'" exceeded the timeout of 3600 seconds.
at vendor/symfony/process/Process.php:1163
1159▕
1160▕ if (null !== $this->idleTimeout && $this->idleTimeout < microtime(true) - $this->lastOutputTime) {
1161▕ $this->stop(0);
1162▕
➜ 1163▕ throw new ProcessTimedOutException($this, ProcessTimedOutException::TYPE_IDLE);
1164▕ }
1165▕ }
1166▕
1167▕ /**
+2 vendor frames
3 LibreNMS/Util/CiHelper.php:397
Symfony\Component\Process\Process::run()
4 LibreNMS/Util/CiHelper.php:210
LibreNMS\Util\CiHelper::execute()
Thanks!
