Time Based Alerts for Interfaces & Bits/sec
I have a question. Is there anyway to create a time based alert for certain time periods?
I have interfaces and have established a pattern of how the Bits/sec fluctuate during certain times of day for our traffic flow on the Interfaces.
Could we create an alert rule for a time range and if the Bits/sec for one interface is either higher or lower than our typical fluctuation then we get an alert?
It looks like a PR is in progress for this #https://github.com/librenms/librenms/pull/11622 which i think you can test as well if you want to.
Otherwise in the meantime you could try the macro method and add it to your alert rule
#Alert rules - Time range
but note this small bug with the macro method #Custom alert macros are not re-evaluated
