I get timeouts when adding a new device via SNMP but existing devices continue to work with SNMP.
I have done a fresh install and then brought my configs over so this tells me its something with my configuration but I am not sure how I broke this.
nginx error log is giving me
upstream timed out (110: Unknown error) while reading response header from upstream,
php-fpm logs are clean
librenms logs are also not showing anything related to adding a device.
Below is my validation. Is there anywhere else that I can go to fix this?
[OK] Composer Version: 2.7.2
