I’ve search quite a bit for this but cannot seem to find an answer so here we go:
I installed libreNMS to a system configured for timezone CST. Pretty sure all that worked fine at the time.
Recently switched to UTC everywhere. the php files were changed from CST to UTC, system time was changed to UTC, as well as the user(s) preferences in the GUI. What I cannot seem to get fixed is the graph windows, where you enter the time frame you want. It continues to show CST while the graph itself (axis) is UTC. I have even rebooted the entire host to try and make sure there was not some process still hanging around during my debugging that didn’t pull in the change…
You can see in this picture, the graph is in UTC while the “from / to” time is in CST. Frustrating.
Thoughts?
root@NMS HOST:/etc/php/8.1# find . -type f | xargs grep -i timezon
./fpm/php.ini:; Defines the default timezone used by the date functions
./fpm/php.ini:; https://php.net/date.timezone = UTC
./fpm/php.ini:date.timezone = UTC
./fpm/php.ini.bak:; Defines the default timezone used by the date functions
./fpm/php.ini.bak:; https://php.net/date.timezone = America/Chicago
./fpm/php.ini.bak:;date.timezone =
./cli/php.ini:; Defines the default timezone used by the date functions
./cli/php.ini:; https://php.net/date.timezone = UTC
./cli/php.ini:date.timezone = UTC
./cli/php.ini.bak:; Defines the default timezone used by the date functions
./cli/php.ini.bak:; https://php.net/date.timezone = America/Chicago
./cli/php.ini.bak:;date.timezone =
root@NMS HOST:/etc/php/8.1# cat /etc/timezone
UTC
librenms@NMS HOST:~$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
librenms@NMS HOST:~$ ./validate.php
LibreNMS | 24.1.0-99-g851f68215 (2024-02-22T17:07:49+00:00)
DB Schema | 2024_02_07_151845_custom_map_additions (290)
PHP | 8.1.2-1ubuntu2.14
Python | 3.10.12
Database | MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.7.1
While I’m at it: Is there a way to invert the Y axis to reverse the in/out graphing?
Thanks,
