HI,
I want to create a new alert rule to alert me when my printers toner level is low than 15%.
I tried the next Entity options: “%toner.toner_capacity = “=<15” && " | " %toner.toner_capacity <= 15% &&” - but without any success…
What is the right \ recommended steps to create that kind of rule ?
Thanks for any help
try
%toner.toner_current <= 15
Thanks for your answer @Kevin_Krumm !
But unfortunately it’s still not alerting me.
This is a screenshot of my rule:
What I’m doing wrong???
I’ve forgot to say, just for testing my alert I’ve configured the toner level to 50%. (all my toners level is currently above 15% right now…
not sure but capacity will not work because that value is always 100%
the toner.toner_current should be the value of the current toner supply.
maybe try
%toner.toner_current < 50
Worked like magic!
Tnx @Kevin_Krumm! for your time and your quick help.
