Hi ,
Could you add TONER under “Health” menu like memory, storage, temperature.
Otherwise we must look toners one by one under every network printer.
Best regards.
Bahadır Birden.
Hi ,
Best regards.
Bahadır Birden.
Should be fairly straightforward - http://librenms.example.com/health/metric=toner/ already works, so it’s just a matter of linking it in https://github.com/librenms/librenms/blob/master/html/includes/print-menubar.php#L364
That seems like a nice one, if you prefer to see all toners in one graph per printer you could also use http://librenms.example.com//devices/type=printer/format=graph_toner/
Ooh, I like that one. And now I realise that’s accessible via the dropdown at the right of the lists/graphs header.
Dont forget to add printer counters
I have 1500 printers connected to librenms for only one site.
and http://librenms.example.com/ examples are not working.
You should replace the http://librenms.example.com/ part with the url of your own librenms server
COMPLETE:
This feature seems already included.
