Suddenly (18/8) my Top devices and top interfaces stopped working.
They just show: “Problem with backend”
Other widgets (alerts / logs) were also empty.
As it was time for a Jessie>Stretch update, I migrated DB/RRD/Config to a new install.
Alerts and log were again populated, pollers works etc, but top devices/interaces stills shows “Problem with backend”.
Nothing in /opt/librenms/logs
Other RRDs are populated and updates without issues as far as I can see.
Component
Version
LibreNMS
1.42.01-43-g3a6f143c8
DB Schema
258
PHP
7.0.30-0+deb9u1
MySQL
10.1.26-MariaDB-0+deb9u1
RRDTool
1.6.0
SNMP
NET-SNMP 5.7.3
[OK] Composer Version: 1.7.2
ran:
./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Overnight, the issue fixed itself. Did run daily.sh and had several reboots before, but didn’t get to test the link above.
Cannot confirm what did the trick, but all seems to be working again.
