Top devices widget - device limit issue
After the last update ( 1.46-69-gce97905 ) , the top devices widget Memory Usage and Processor Load no longer limits the Numer of Devices and displays them all in the widget.
We have 200 + devices and this cause a slow load for the dasboard and significant increase of space on /opt/librenms/logs/access_log and of course lots of unwanted requests.
The limit works for the same widget but for Response time or Disk Usage or Top interfaces.
This is being looked at.
I’m having the same problem, needed to remove the widget since it was creating a high load on my server trying to show the CPU load for all devices.
murrant is working on a fix should be submitted to master. If you are on dev daily updates you will get it if not you will get it on monthly releases.
