Joris
5 December 2018 11:21
#1
We’re facing an issue with top interfaces. In this list some down interfaces show up, which is kind of weird. These interfaces have been down for several months already.
I have tried manually deleting the interfaces in the DB, reset counters on the switch, but all to no avail.
Anyone has an idea?
Component
Version
LibreNMS
1.46-6-ga0d7666
DB Schema
273
PHP
7.0.32-0ubuntu0.16.04.1
MySQL
10.0.36-MariaDB-0ubuntu0.16.04.1
RRDTool
1.5.5
SNMP
NET-SNMP 5.7.3
[OK] Composer Version: 1.8.0
Joris
5 December 2018 12:28
#3
Validate output was already posted below the image.
All cleanup options are turned on, like in the doc. This does not make any difference
$config['syslog_purge'] = 30;
$config['eventlog_purge'] = 30;
$config['authlog_purge'] = 30;
$config['perf_times_purge'] = 30;
$config['device_perf_purge'] = 7;
$config['rrd_purge'] = 90;
$config['ports_purge'] = true;
Are you purging ports in the Web UI in the ports menu
Joris
5 December 2018 13:23
#5
Yes. But in fact these ports should keep existing, they are just down and hence no traffic
okay… what about your settings on the widget?
@Joris Hi Joris, May I know is this issue solve from your end?
Joris
21 February 2020 10:16
#9
Looks like it’s resolved with a recent update
Do you just perform daily update and the issue fix automatically?
Because after I perform daily update, it still showing down ports…
