[OK] Composer Version: 1.6.5
[WARN] Your install is over 24 hours out of date, last update: Sat, 30 Jun 2018 21:37:37 +0000
[FIX] You can switch back to master with git checkout master
Modified Files:
logs/.gitignore
rrd/.gitignore
[FAIL] We have found some files that are owned by a different user than librenms, this will stop you updating automatically and / o
r rrd files being updated causing graphs to fail.
[FIX] chown -R librenms:librenms /opt/librenms
Files:
/opt/librenms/conf.d
/opt/librenms/conf.d/config.custom.php
/opt/librenms/conf.internal.d/syslog.conf.php
/opt/librenms/composer.phar
Story itself is as follows.
Added TP-Link T1500G-10PS into LibreNMS and it is recognized as TP-Link, platform itself is not recognized.
Now comes the funny part, on discovery, sysObjectID is reported as: .2.3047088.1280.20042.1702122356.1919246701.540552528.1869771808.1198090081
After next poll, it resets to .0.0.0.0.0.0.0.0.0
If I run rediscover it returns sysObjectID as .2.3047088.1280.20042.1702122356.1919246701.540552528.1869771808.1198090081 again.
Same happens with T1600G-52TS TP-Link device with latest updates. I assume this is a bug in TP-Link firmware, since it returns crap over plain snmpget (what LibreNMS ultimately does):
If snmpget/snmpbulkget happens with a single OID, correct data is returned. If multiple OIDs are requested, we see what we see.
Possible solutions: rewrite the source for this exception on TP-Link or request support from TP-Link. Unfortunately, this task is of low priority at my work, so I did not invest any time in this, sorry…
Can I ask firmware version you are running on that?
Interesting thing is, that despite the different tool outputs I provided them, they are seem to be unable reproduce it.
Also, could you run tcpdump (on LibreNMS host) when you execute that query on LibreNMS and send it to me via email?
Will provide you with my email address via PM.
