Traceroute not included in E-Mail Alert
./validate.php is clear.
No problem with traceroute operation (manual confirmation)
I configure the alert-template as below, but it doesn’t work.
[Alert-Rule]
SELECT * FROM devices WHERE (devices.device_id = ?) AND (devices.status = 0 && (devices.disabled = 0 && devices.ignore = 0)) = 1 AND devices.status_reason = “icmp”
[Alert-Teampltes]
  1. First Try : status 0
{{$alert->debug[‘traceroute’]}}
@if ($alert->status == 0)
@if ($alert->status_reason == ‘icmp’)
{{ $alert->debug[‘traceroute’] }}
{{ $alert->debug[‘output’] }}
@endif
@endif
  1. First Try : status 1
@endif
@endif
Is there anyone who can help?
Thank you for time
Do you have debug.run_trace set to true?
$config[‘debug’]['run_trace] = true;
yes.
  • config.php
$config[‘debug’][‘run_trace’] = true;
$config[‘traceroute’] = ‘/usr/bin/traceroute’;
$config[‘show_services’][‘traceroute’] = true;
  • ./test-template.php
Even if you execute it, it comes out blank.
Hmmm…
All I had to do was set this in my global config:
  • debug.run_trace true
Then added this to the bottom of my alert template:
@if ($alert->debug['traceroute'])
   <pre>{{ $alert->debug['traceroute'] }}</pre> <br>
@endif
When a device is down, does a Traceroute widget appear on the device’s overview page?
If no - then doublecheck your global config setting.
If yes - then it’s likely an alert template issue.
